I need to have an assembly welded together made from 15mm steel bar. The assembly is made up of several parts which need to be bent prior to welding. How do I draw the bends in the bar?
Draw a line as the path you want your bar to follow centred on the bar. Then draw a circle and use Follow Me.
Draw a centerline for the rod and a circle at one end with a diameter that matches and use Follow Me.
Simon by a nose!
Wow, that was quick, thanks
Thanks to you too.
I’m sure this is going to come across the wrong way, but how could you use sketchup for 4 years and not know about using follow me.
I’m really not being rude, just curious about your workflow.
I use Sketch Up infrequently, so often forget how to complete some things. It’s what happens when you get old!!
Ok, got you. I often suffer from the hereafter problem, when you walk into a room and think to yourself, now what am I here after.
The ‘follow me’ worked fine thanks!
