Grundrahmen.skp (428.1 KB)
Good morning everybody. This component is measured in inches, I would like to know how I can change it to millimeters.
What do you mean? In your model you already have units set to millimeters.
Hello friend, thank you. But what I need is to edit the component. In this case, this component was created in Inches, and I would like to change the component to millimeters, as shown in the image. I tried to edit the component, but I didn’t find any specific field where I could change from Inches to Millimeters.
Edit the LenX and LenY attributes to display in millimeters.
One question @DaveR are your images from SketchUp 2024? I’m having problems with Component Options in sketchUp 2024, I watch the window but there is no data in it. Hoever I have no problem in SketchUp 2023.
Thank you very much. Exploring the component, I discovered that I can change everything, including the label language. Have a good day.
Yes. That’s in SketchUp 2024.
Make sure you have the latest version of the Dynamic Components extension installed.
You’re quite welcome. And yse, there’s a lot you can do. Maybe change the LenX and LenY labels to something that means more relative to the object. Maybe Width and Length.
I guess I don’t know what the problem is. Maybe @colin has some insight.
What I wrote in this message is still the same in 2024:
If you select a component and open the two windows, you won’t see the problem for the rest of that session. If you open both windows before selecting a component, you will see the problem for the rest of that session. When you saw it work in 2023 and not in 2024, you had done different steps.
@DanRathbun came up with a patch a while back:
