How would I go about changing the wall thickness on this model from 1/4" to 1/8" and still keep the inside radius 2 3/4"?
demo.skp (1.3 MB)
Thanks,
demo.skp (1.3 MB)
Thanks,
Come Ca?
demo.skp (1.3 MB)
I used the offset tool to create new edges parallel to the inside (they needed little extensions at each end due to the shape) and pushpulled them down to the bottom. On the top tab, I had to use ctrl pushpull because of the holes. Then I cleaned up the extra stuff at the back of the tab and fixed reversed faces.
If you are willing to use Extensions, Fredo’s Joint Push Pull works without a problem:
Note that you also need LibFredo6, as well.
Not sure what you are asking.
I will try it that way, thanks.
I will be checking out that extension for sure, thanks!
Open the model I uploaded.
So “Come Ca” is French for "Like that? ![]()
Oui comme ça. Merci!
If I could spel Id be danjerus. ![]()
