I’m trying to export my sketchup model exactly as shown (it is also on the first floor of my model):
When I go to Export > 2D graphic it comes out like this:
It is also the same thing when I put it into Layout:
Does anyone know how to fix this?
This looks like a typical integrated graphics card issue. Could you share the SketchUp file so we can try on a different machine to compare the results?
ah I hope not, I’ve only just got this computer and I had issues with my graphics card and sketchup on the previous one. I’m also not using my integrated graphics card I’m using my nvidia one. The file is a bit big so I’ve attached it via a wetransfer link.
This is a png export from SketchUp:
Your entire model covers a huge area relative to what you are showing in the scene. Copy this building to a new file by itself and move it close to the origin. Or delete the rest of the model and save as a new file. This should help you work around the problem. If you do that remember to purge unused.
Your profile needs correcting then.
FWIW, you have a fair amount of incorrect tag usage. Probably mostly due to imported stuff.
And there’s some stuff that could stand to be purged.
I’ll try it thanks! do you still think it could be an integrated graphics issue or is this to do with the file itself?
Well if you aren’t using an integrated graphics card it wouldn’t be that although integrated graphics tend to be more problematic. I think your model, being spread out over a large area, again, relative to the small area you’re looking at, doesn’t help. OpenGL(the graphics software) can get confused when that happens.
Okay thanks for your help
The model is orientated based on where it is pointed in real life what sort of problems can this cause?
I’m still pretty new to sketchup so many feedback or things I could do better is appreciated
The surfaces in the model are misoriented, not the model in space! They should be white or gray, and those with a bluish tinge are not well oriented. Click on the floor to select it, then right click and select: Invert planes
I’ll do this, thanks
I see the same issue when I export as pdf but not as png. I haven’t found a specific cause yet, though. It may be a bug in the pdf exporter. I don’t know why that would affect LayOut.
Here are some more suggestions to help improve your modeling.
Regarding @Sturnus comments, it is best practice to build a model in monochrome mode so that you can see and correct reversed faces as you go. Only apply materials to faces after you are sure they are correctly oriented with their front sides toward “air” and their back sides toward the inside of an object. Many of us use an obnoxious color for the back side of faces in the default material so that reversed faces are very evident (I see that he already showed you that).
Edit: looking at the title, I would also comment that SketchUp’s hidden flag should be used only for temporary assists while building a model and unhide applied as soon as no longer needed. SketchUp’s management of this flag is primitive and contains subtleties that trip novice users (e.g. “Unhide All” should really say “Unhide All in Current Edit Context” - it does not reach inside groups or components that are not open for edit!
The PDF exporter from SketchUp is a very different beast than the PNG or JPG exporters. Export to PDF or EPS creates a pure vector file. In my experience vector exports are more easily confused than raster that are just glorified screenshots. When a model is complex, vector elements are easily left out, or, for instance, stacked wrong in the resulting file.
I did a test by switching to Shaded with Textures and exporting to PDF. I got this:
