I am coming from SU2017 where hide/unhide geometry or components was a model based thing and not a scene based thing?
I am finding in 2020 that if I hide a component in one scene and switch to another, the geometry is not hidden in that scene. And returning back to the original scene, the object I hid is no longer hid.
It seems I had to “update scene” to make the hide command stick.
This never used to be the case. As I said, the “Hide Geometry” was a model based command and not a scene based command. and certainly never attached to the update scene command either.
Is there a toggle or setting for this?
With hundreds of scenes already made, hiding the same object in each scene and then updating that scene seems pretty frustrating.
Not updating the scenes after making changes has always resulted in the scene-specific changes not being remembered.
Select the scenes you want to update in the Scenes panel. Click the Update button. Then deselect all but Hidden Geometry & Objects in the Properties to save panel and finish updating.
It used to be scene based but only in the top level drawing context. It has now been changed to be more consistent and works the same also in other drawing contexts.
FWIW, if you are just using the native method of doing this, you can select all of the scenes by clicking on the top one and then holding Shift while clicking on the last one.
I know you did but since what you asked to be able to do can be done without any extensions, I figured I’d add it in case someone else is looking for a native way to do it.
Thank you, this is helpful. I, like TBourne have been frustrated with this change as I was used to hidden geometry being hidden throughout. I do like the flexibility to toggle visibility from outliner and have found that feature very useful during my modeling work. It took me a while to figure out what was going on when I would reload my model(house) into various SU models that I use for layout (Site, sections, elevations etc) and find that all the pieces I had carefully hidden had become unhidden and I had to perform all that work again. Now I want to request an additional feature where we can toggle visibility on/off and permanently off. Three options and we would have the best of 2019 and 2020.
Thank you for your contributions to this forum.
