Hi.. how can i find groove in cut list
hi.. how can i find groove in cut list
You need to have a pro subscription to use extensions like Open Cut List (OCL).
What is the best trick to use to keep work from getting interrupted?
Are you making your parts into components? You can also make your parts groups, but I prefer components. If you make components and tag your components, then your can keep the geometry from sticking together. Is that what you are asking?
What is it you are actually trying to do?
What do you mean? How is your working getting interrupted? What does this have to do with your original question?
Please cleanup your forum profile. There is no Free (web) 2021 version. Are you actually using a cr acked version of the desktop version of SketchUp? What graphics card are you using? There’s nonsense in your forum profile.
Yes, but I would like to explain to the technician working at the factory that this part needs to be emptied.(groove)
Perhaps we can assume they are speaking of CNC routing?
@boris.beaulant ping
When the details of cutting, perforation, tape EDGE, and GROOVE are not clear to the technician at the factory, this will certainly lead to a disruption of work and an error rate.
I’m sorry. I am not the right person to explain to a CNC technician what to cut, perforate, etc.
Make a part drawing with a label or some sort of graphic indication of what you want?
I am also sorry and apologize for the inconvenience and
thank you for your ATTENTION .
This isn’t trivial information to display in a cut list.
To be precise with your operator, you need a lot of information:
  • Groove yes/no
  • Groove width
  • Groove length
  • Groove depth
  • Groove position
  • Face to be machined
And all of this should be repeated by the number of grooves on the part.
I believe that only a classic technical drawing of the part can provide all this information in a single document without confusion. This type of drawing can be easily done with Layout.
