Hi
I have being tried to make a window opening in the front
wall to fix the window frame without success. As you can see I have no trouble with making other windows, just this one. Help please.
hi,
you’re fresh on this forum. If you heck around, you’ll see the first step when reporting an issue is to share the file.
and I can see already from your screenshot that many (most?) of your walls have no thickness. looks like you removed one of the two faces. basically any blue-grey wall is not good.
Without seeing the model, I would guess that the faces (the missing one and the one we see) of the wall are not parallel but there is a small error.
Hi Anssi:
How can I fix it?
You should first learn the basics. SketchUp Fundamentals (Desktop)
