Creating the actual curves are no problems ofc. but then to figure out a way to make the curve have a smooth elevation from the start at 0m the tip at 20m is where I get stuck.
So if anyone has any suggestions please let me know.
Thanks!
Something like this… though I just copied the bottom curve from the top and scaled it up a bit.
I traced the curves over the image using the Arc tool, keeping successive arcs tangent, with the image horizontal. Then rotated the curves around the red axis.
Thanks John for the reply!
Have to say I did not fully understood your process to achieve that, so maybe it will work for what I want to achieve myself. But one more factor is that the walls need to be straight and it’s also important that I can follow the curves drawn horizontally as the model I’m working on is made with geo-locations and I want to be as accurate as possible positions.
