Help please with stone setts for landscaping?
Hello
I have been trying to use Sketchup for a landscaping project. Some paving I have added is in a circle. But when I try adding an edging to it around the perimeter (around a 100mm edge). I then use one of the stone textures to add the colour which just fills in the area. But does anyone know how I can make it so it has individual stone cobbles around the perimeter instead?
Like for example, when you have a patio and it has a stone cobble edging all the way around? (If that makes any sense).
You could use DaveR’s response and find a circular texture. Another option to consider is to just take one cobble and use the ‘polar array’ function to copy it around your paving circle. See example below. FYI - I made my cobble a component so if I edit one, they all change. I also gave it a slight thickness so that it didn’t ‘z-fight’ or show the grass texture from below through the cobble texture.
pavers circle
Thankyou very much for your help. At this stage I am a novice at Sketchup. I have just tried looking for circular textures in the 3d warehouse, I can’t find any.
Is there a website out there where you can download textures and import them into Sketchup?
https://www.sketchuptextureclub.com/ try this site. Also, if you’re new to learning SketchUp, check out this video for more info on arrays on our SketchUp Campus - https://learn.sketchup.com/course/move-tool/copy-and-arrays.
Thankyou very much. I will take a look :smiley:
