Help me here, why is this not a solid?
I need your help here forum. This model is not a solid and i cant figure out why, its driving me crazy. Solid tool saus i got surface borders (holes) and stray lines. This one is making me go mad, i have no idea where to find whats making this problem, can you help me?
Not a solid.skp (2.9 MB)
With Solid Inspector running hit Tab to zoom in to each of the errors. Once you find one, fix it. Run Solid Inspector 2 again and find the next to fix. Rinse and repeat.
BTW, I would suggest removing those knife edge parts that rise up above the flat surfaces.
And fix the incorrect tag usage. ALL edges and faces should be untagged.
You are magic! How on earth did you find thoose!? I have been using solid inspector and cant se where the problem is. Is there a way to zoom to the issue?
-Hit Tab you wrote.
will try that now.
I did what I directed you to do. I hit Tab to cycle through and zoom in to the errors.
Are you using the old Solid Inspector or Solid Inspector 2?
Yes. That’s it.
Thank you!!! I never knew that was an option. If it was writ large somewhere I missed it.
Glad to help.
Not writ large but it is writ. :zany_face:
Neither did i! Love forums and experts :slight_smile:
But now i get this hmmm.
Solved. Exploded the group and regrouped. :+1:
Solid Inspector2 doesn’t catch all possible errors, unfortunately.
Using X-Ray can help find errors too. Cheers, Steve
usually, when solid inspector2 says that all is well, but the object isn’t solid, I try with solid inspector (the original one). It’ll often circle a couple of problematic things. it’s worth keeping installed.
