Hatch Patterns - at a loss
I’m trying to evaluate whether it’s safe to migrate from SU2025 => SU2027 now that Skalp Studio is available in beta (separate issue).
I’m just trying to get the new native basic hatch pattern functionality to work and I’ve either misunderstood the feature, doing something so basic and fundamentally wrong or there is bug somewhere.
I’ve looked at the documentation but it seems extremely simple and almost impossible to misunderstand. I tried the ‘AI Assistant’ but that was next to useless as it appears the AI is unaware that SketchUp 2027 even has a Hatch feature (which is a pretty poor show by itself).
If I set a Section Fill in the material it does not appear in the section, regardless of style, hatch etc.
Create new materials with a different hatch - nope.
Delete the section plane => create a new section plane - nope
If I choose an object and select a section fill in the entity info - yes
If I delete the section plane => create a new section plane, the objects section fill (set in the entity info) is removed!
What on earth is going on? I cant make head nor tail of it.
Any Ideas?
Hi,
Have you enabled the new rendering engine in the preferences?
Sorry, I only have the French version.
Yes, its on by default.
Also, that would not account for hatches showing temporarily if set via entity info and not via the material.
you’ll have to share your file for someone to take a look at it.
hatches are new, we don’t know all the issues by heart yet :wink:
its literally just a copied box in a new file.
TEST_HATCH.skp (5.8 MB)
I made a box, grouped it, copied it a few times, added a section plane. Thats it
Hi Dave
Thanks for this
Why is there a section fill slot for hatches in the material editor?
Documentation explicitly states that hatches are set at the material level and can also be at an object level via entity info.
I take your point on Skalp, the plugin isn’t live in this file but the plugin had been active previously.
I’m having problems wrangling Skalp Studio as it is and maybe the Skalp default material takes precedence over the natively assigned hatches (which thinking about it would probably make sense from a Skalp management perspective, as otherwise things could go sideways real fast unless there was some kind of management priority enforced)
In Entity Info, you are overriding the hatch patterns from the material. It was set to Skalp - Default as Dave pointed out.
If you set that to no hatch, the material hatch works.
I understand that but you select a material scope level hatch in the material editor.
For object level hatch setting => entity info
ah, so object level (entity info) overrides material level hatches.
My apologies.
the problem was that you said that a hatch set in the Section Fill slot in the material editor was not supposed to appear in the section - and that confused the hell out of me.
I didn’t say it was not supposed to appear in the Materials Editor panel. Just that it wasn’t edited there. My apologies for attempting to help. I’ve deleted my previous posts. I think @d13tz will help you get it sorted.
Correct. If you set the material hatch, and don’t set an object hatch, it should work properly.
You did say that, and I was just trying to work out where to go from there, thats all, its a new feature & I was trying to understand the nuances of it.
You were a help and I do appreciate it, because now I do have more of an understanding of it & it looks like even though Skalp wasn’t active in the file, deleting the Skalp material worked. Skalp obviously sets everything at an object level initially, so thanks for the lead in regards to Skalp.
“If I set a Section Fill in the material it does not appear in the section, regardless of style, hatch etc.”
Evidently I didn’t explain well enough. Again, my apologies.
Click on the section fill material, that will bring up the dialog to select a hatch pattern.
