I’m hoping someone can help me. yes I’m new but I’ve searched and as far as I can tell my guides/dimensions should be visible.They show up while I mark them and as soon as I set them they vanish. But if I select all I can see them, or if I click exactly on them which takes a few tries to find, then it shows up. The guide lines and the dimension measurements are invisible.
I can only post one image so I’ve compiled what I hope will help show what I’m seeing:
This is what I get for clicking around on things I don’t fully understand.
Thank you. I didn’t find this answer anywhere.
My plan right now is to learn SketchUp, which will require I understand what I’m clicking on. This sounds silly, but I really got into building houses in The Sims4 video game, and wanted to do something more real world.
When you use SketchUp (SU), observe the status bar below the modelling window. SU is constantly telling you what you can do.
Open the Instructor Window and explore what it is telling.
Place the cursor over each Tool to get a text telling you the name of the tool.
Right click on objects in you model to bring up contextual menus. Look at the choices that are proposed in those menus.
Click on each of SU’s menu on top of the window and open all the sub-menus to see what is proposed.
When I started using SU that was at version 3.0. Using the above tricks, I learned the program. I also learned a lt by being a regular of @Last help forum.
