I am unable to group all the drawing elements in the model when “View…Hidden Geometry” is enabled.
An example model is an ungrouped cube with a simple edge line off to the side. With “View…Edge Style…Edge” disabled the edges of course are hidden. Performing a select all results in the cube faces (and associated edges) being selected, but not the loose edge. Grouping the selection results in omission of the loose edge missing from the group. A simple “View…Hidden Geometry” doesn’t fix it as the edges remain hidden.
The solution is to enable edges prior to select all. Is this correct behavior?
