Grouping faces in component changes position and rotates
When I try to group a number of faces in a stretched component, the position changes and rotates slightly. I also noticed when drawing a rectangle in this component, it doesn’t make it straight. Does anyone know how to fix this? I need to draw more detailed infill in this component. Thanks!
I suspect that you have a nested component that is skew. (the angle between the red and the green axes isn’t 90 degrees due to scaling)
See if one of your components gives you the option to ‘Reset Skew’ after right clicking on it (them).
If so, use a different workflow to achieve your scaled component(s), not scaling them with rotated axes.
That’s it, thank you! I scaled and mirrored some components so it might have something to do with that. Didn’t know about the reset skew, now I do :slight_smile:
