Hello friends,
When I enter a grouped object and then a nested group inside it, the rest of the group hides itself. What is the reason? I still want to see the entire object.
Thank you,
Monika
Hello friends,
Thank you,
Monika
View Menu - click Component Edit - Turn off Hide Rest of Model.
Learn SketchUp Fundamentals at campus.SketchUp.com
Hide rest of model is On.
See if hitting [Shift] + [h] helps to toggle it of. I think that is the default shortcut key.
Great, that worked! Thank you.
Thank you, it worked
I recommend you to create a shortcut for this task, it’s something that you’ll use a lot, and pressing a key is a lot faster than going to the menu and activate or deactivate it.
