Graphics issue
Simply put…, I have graphics issues in most models. part of the model gets cut off as I orbit/navigate around my scenes. Is this graphic card issue? Please see attached jpg.
System Type x64-based PC
Processor Intel(R) Core™ i7-7700 CPU @ 3.60GHz, 3600 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM) 8.00 GB
Clipping. Is the search term you need.
Very common.
First thing to try is to swap from Parallel Projection to Perspective in the Camera menu.
Well that was easy
This issue comes up so often and has existed so long one wonders whether it is insoluble. When you are familiar with it you know what to do but surely we must all prefer that it didn’t happen at all.
For perspective views, it is “insoluble” as it is caused by the camera picture plane being moved inside the geometry. Parallel views, I think, might be reengineered in a way that always keeps the projection plane somewhere outside the model extents. That would probably cause a large “jump” when you switch from one display mode to another.
