I’m desperately trying to improve my workflow. Our product has rounded edges but trying to have them click together is agonisingly slow! I’m manually pulling cabinets together where corners should meet but with the cabinets having round edges it doesn’t naturally do this.
Is there are way to set them up so I can add some kind of geometry where they would like to click together or perhaps an extension that makes this easier?
Image attached to help explain. Many thanks to anyone that can help!
Thanks MikeWayzovski. I’ve just found an extension called anchor point thanks to another reply on here but I’ll keep this as I think this will come in hand for another application in mind! Cheers
John_mcclenahan. This would be possible however the cabinets will be added to an environment so I wont be able to use the axis lines. The measuring tape would be fine but it wouldn’t increase workflow if I constantly have to do this.
Box. Thanks for this. It’s exactly what I’ve been needing. Simple and effective. This is going to save me hours! Cheers
Sounds as if the Anchor Points plugin is an easier way to get the points you need than drawing them (though that isn’t at all hard with a plugin like PointTool from SkectchUcation).
I don’t really understand this comment. Although I have the cabinets on the red axis, they could be anywhere. You just need to grab one by a corner point with the Move tool, then put that point on top of the guidepoint in the previously placed cabinet, wherever it is.
Mike W. I know enough to appreciate what you did but I never knew about these techniques – loved that tiny gif file and the techniques, of course. I have avoided working with curves because I laced these methods. Thanks! Just wondering. Did you use SU to make that or a screen recorder?
