Hi,
I need a bit of guidance on how best to manage a product range I use for interiors. The product is modular by nature, in that each product can be attached next to one another much like a set of kitchen cabinets. Variable widths, depths, sizes etc.
The problem I’m having is it’s harder than it seems due to rounded edges. At the moment it’s very time-consuming zooming in on both corners and making the necessary adjustments to even things out when I ought to be already placing/sliding/clicking the next item into place.
Is there a way I can make the component more effectively?
Someone suggested hidden geometry but often times it’s all too easy to click on the wrong geometry. How I’ve done it before is by using an extension called anchor point which creates a dot on eat blue box corner. Is there a better way though?
I’d appreciate any kind of help.
I’ll be sure to scour the forums to see if I can help anyone else.
Many thanks.
