Generating report: strange results with mm
With Rohmass_Breite, click the right icon and set the units to cm, then initially expose the attribute to show on the option dialog, set the option units to mm or “end user model units” . Apply. Then go back into the properties and hide the attribute, “user cannot see…,” apply.
The default is text, text is valuated as inches, so you need to specify the unit and the user input
