Generating report: strange results with mm
Hi there,
I want to generate a report with a list of windows/ doors and there measures.
IBut it gets some strange results:
The calculation is quite simple:
The units are set to cm. So “Rohmass_Breite” should be “Breite”+20mm.
But it seems that sketchup messes up cm and inch…
would be nice to have a simple solution!!
Thanks
With Rohmass_Breite, click the right icon and set the units to cm, then initially expose the attribute to show on the option dialog, set the option units to mm or “end user model units” . Apply. Then go back into the properties and hide the attribute, “user cannot see…,” apply.
The default is text, text is valuated as inches, so you need to specify the unit and the user input
Thats it!! Thank you very much! :+1:
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
