Could anyone shed some light into this topic and be my hero!?
Enterprise License 2019
Windows 10
We would like to generate reports out of our retail projects. We have pre-defined furniture elements and only need to export the name + quantity per model for further calculation.
Attached you find the error message, I tried to generate a report with only one box in the file.
If this is the only thing you need you can go to Window menu>Model Info>Statistics and select “only components” from the popup menu. You can then select and copy the contents of the window and paste into Excel or other application. Here is the result from your testfile:
I want to run the report, to see how many defined components (wall elements, podium, etc.) are used. (I do not want to know the pieces of a component). I need to put the number of retail elements out of the report to copy it to a calculation-sheet.
I tried a test with a simple box and followed a video for dynamic components creation. I tried to run a simple report but receive the same errror message.
We are? (I am) able to produce a report from your file, can you run sketchup from another machine?
Or reinstall sketchup making sure you do as administrator
