Free Trial to Sketchup Go
I have purchased Sketchup 2024 Go. How do I change from Free Trial to subscription plan on my Mac?
uhh you have either sketchup 2024 (pro) or sketchup go.
sketchup 2024 is accessible through a pro or a studio licence. it’s the one you download and use from your machine directly, with the extensions and everything (and you’ve used it as a free 7-day trial)
sketchup go is a combination of the ipad version - if you have an ipad - and the web version with extra tools.
it’s accessible here.
https://app.sketchup.com
Hi. I have Go. It still opens up with the free version. How do i change it to the bought version? Thanks
it’s the same interface. it looks the same.
https://app.sketchup.com/
for instance, on your right, check the outliner panel, does it work ? can you open it without sketchup asking you to upgrade ?
edit : here are the two interfaces, go and free.
as Dezmo said, you might need to log out and in again. otherwise, you’ll have to check in your profile that you allocated the licence to yourself
Make sure you use the email address you used or provided when you purchased your subscription to sign in.
You may need to sign out
and back sign in for it to take effect.
The Trimble Account Management Portal (AMP) (Manage account menu on the above screenshot) helps you see and manage your Trimble subscription products.
