Follow Me on Odd Shaped Molding
I am trying to create a molding profile along a non-rectangular edge. I am getting nowhere. Can anyone help? I have uploaded the model to this message. Any help you can provide will be appreciated.
End Table Between Sofa & Recliner - Final.skp (133.8 KB)
You can’t run Follow Me around the four different components in one go. If I were doing this, I would trace the perimeter of the four components to create a path (I’ve moved it straight up above the components so it’s visible). And I would create a “cutter” profile.In this case I used a circle but it could be a quarter circle drawn with the Pie tool.
Use Follow Me to extrude the profile around the path. Make the extrusion a solid group or component.
Use the native Solid Tools or better, Eneroth Solid Tools or Bool Tools 2 to trim the components with the extruded cutter.
FWIW, for Follow Me to give you expected results, the profile must be perpendicular to the first segment in the path and the extrusion will end perpendicular to the last segment in the path. Putting the profile in the middle of the path and perpendicular to the red axis made it simple to get it set up correctly.
