Hello all.
First post here so please don’t be too hard on me.
I’ve been using Sketchup on and off for a long time (since V3 I think) and consider myself reasonably competent. I’ve suddenly found something that I’ve relied on though has stopped working - using the Follow Me tool to extrude spherical or part-spherical forms.
Now the shape I was trying to create was relatively simple (a basically bullet shaped end on a cylinder) but it was in a relatively complex model, so to check the problem wasn’t actually some unnoticed geometric error in the model, I went back to square one, opened a new file and tried to draw a simple sphere by the tried and tested method of using the path of one circle to “extrude” a second, perpendicular, circle into a sphere (the method here: Spherical triangle help). However when I click with the Follow Me tool on the second circle, rather than extrude into a sphere the circle simply disappears. So what’s going on? Is there a bug in V16 or has something fundamental changed? Or am I being dumb?
Ta
Phil
