Fluctuation of time in between Scenes
Is there a way to fluctuate the time in between Scenes. As far I can see; there is only one time setting possible. During a presentation film it would be a great help if the time could be fluctuate. e,g, to cut the film/waiting time.
SketchUp only has one setting for transitioning between scenes.
There is an old ruby plugin that allows you to create different transition times. It is called “scenes_transition_times.rb” and it can be found here - https://sites.google.com/site/morisdov/
I haven’t tested it with SketchUp 2014 and you should be aware that when generating an actual movie/video from SketchUp, SketchUp does not initiate ruby scripts and therefore the video will not contain the customized transitions. You will have to record it using a screen capture program like Camtasia.
Since it is a .rb and not a .rbz you cannot use SketchUp’s extension installer. You will have to place the script in the correct SketchUp directory.
See this article for installation instructions - http://help.sketchup.com/en/article/38583
Cheers
CD
There’s also PageUtilities2 and PageUtilities.
