Flowify ne fonctionne pas, il indique « ERREUR D'ENTRÉE : entrée insuffisante »
What exactly did you try?
Did you follow the tutorial I made, presenting the simpler method in this case?
(click on the arrow to expand and see the clip)
Which is the model you want to create, because there are two different ones in your files. And both are already extruded in certain areas.
