Some advice or help would be fantastic. I have dropped all electrical and lighting onto the floor plan in layout, however, placing the wires using the arc tool makes the floor plan and furniture disappear when drawn. i have the layers in the correct sequence and am unsure why this is the case. Some help please to correct the issue.
It would help if you share the LayOut file so we can see what you have going on. It sounds like you have a layer lower in the layers list active when you are adding the arcs and so on.
What operating system? 2024 Pro is NOT and operating system. It would be some for of Mac or Windows operating system.
Sorry, windows system.
Put that in your forum profile, then.
And share the LayOut file so we can help you.
That’s not the same as sharing the .LayOut file.
Turn off Fill in the Shape Style Tray when drawing the arcs.
Fantastic. Such an easy fix. Thanks for your advice.
It was easy for you to miss because the fill color was white and transparent.
