I’ve exported a model onto a previous model as the model have coordinates embedded in its data. However, there were remnants of the previous (badly drawn) model which i neglected to delete (with solid inspector) before pasting the new model in. Even after removing the remnants (structural lines, invisible and only visible when highlighted in solid inspector), my model continue to flicker. The only solution i know of is to redraw the whole model, which is impossible as there’s quite a few other models with similar errors.
Anyone ever faced such a problem and know of a solution? Thanks!
Really dont think so though, all other models that have the remnants removed beforehand have completely no problems, so im quite sure its somehow the ghost of those leftover lines causing it.
Also, make it a component and then save that component.
Open it or import (that component) into a new model. That seemed to eliminate it after exploding.
