Flickering faces import IFC due to component axes
A quick one…not really tested, but it looks like is O.K :innocent:
No guarantee! Use your own risk!
Backup, Backup…
Follow the animation:
  • Select the desired components, groups or everything (Ctrl+A)
  • Open Ruby Console
  • Copy-Paste the code from below into Ruby Console
  • Hit Enter (Return)
The axis origin of selected components, groups will set to its bound left front bottom corner. Including all nested…
You can Undo it.
Dezmo_reset_axes
module Dezmo
module Reset_Axes
  extend self
  def transform_obj_origin(obj, point)
    tr = Geom::Transformation.new( point )
    obj.entities.transform_entities( tr.inverse, obj.entities.to_a )
    obj.instances.each { |instance|
      instance.transformation = instance.transformation * tr
      @count_inst += 1
  def set_origin(definitions)
    definitions.each{|obj|
      point = obj.bounds.corner(0)
  def get_defs(instance)
    @definitions<<instance.definition
    classify(instance.definition.entities).each{|inst|
      get_defs(inst)
    true
  def classify(ents)
    componets = ents.grep(Sketchup::ComponentInstance)
    groups = ents.grep(Sketchup::Group)
    componets + groups
  def run
    model = Sketchup.active_model
    sel = model.selection
    @definitions = []
    @count_inst = 0
    if !sel.empty?
      classify(sel).each{|instance|
        get_defs(instance)
      @definitions.uniq!
      model.start_operation('Dezmo:Reset_Axes', true)
      set_origin(@definitions)
      model.commit_operation
      puts "Axes reset to bound left front bottom corner:"
      puts "Definitions:#{@definitions.size} Instances:#{@count_inst}"
Dezmo::Reset_Axes.run
Some bits from Thomas Thomassen ( thomas[at]thomthom[dot]net). Thanks.
