Fix G500 texture
Hi everyone, I’m having a recurring issue in SketchUp 2024.
Whenever I move a component or insert a new one into the model, SketchUp freezes for a few seconds. When it unfreezes, all the textures in the model appear distorted or misaligned, even those not related to the component I just moved.
To get things back to normal, I need to use the Undo command, and it shows:
“Undo Fix Textures G500”
This happens across different models and textures. It’s really affecting my workflow, and I can’t find a setting to disable this automatic texture correction.
Has anyone experienced this? Is there a way to turn off this “Fix Textures G500” feature?
Something in that material needs fixing. In some cases if the problem isn’t fixed, it could lead to SketchUp crashing.
Are any of the components you see the problem with ones that are from 3D Warehouse, so I can try it? Or, could I try your model before it has the component inserted, along with the component?
Check to see how far from the original the component is being placed.
