I have made a component and save it. I cant find it as saved anywhere. Its not saved as a skp file where everything else is (in my docs folder). Is there another file type and default locations for components?
I have highlighted the component and Ctrl C and Ctrl V to duplicate it, which is useful saving time and does the job for now.
But to pull out a previously made component from a saved list is what I cant find.
When you first create a component, it is saved inside the SketchUp file you are currently editing, and it is visible in the In Model tab (little house icon) of the Components browser. If you want to save it as a separate file, you can right-click on an instance and select “Save As…” from the contextual menu, and you will be prompted for a filename and a folder in the usual way.
Where is it saved in 2017 Make? I’ve tried to save several components, and there’s no sign of them anywhere, especially not in the “components” file location in “Window->Preferences->Files”. And when I try to context-click and “save as”, the component is deselected as soon as I right click.
Anywhere else in the model space. When you right click on a component you should get a context menu with a number of different options to select from. Is it possible you’ve got the right mouse button assigned to something other than right click?
Dan, that’s a good idea. I’ve been navigating there in Explorer, and it gets a little old. Dave, I tried again in a blank workspace to be sure I was remembering correctly, and it worked as it should. If I figure out what I was doing wrong yesterday, I’ll let you know, but I’m pretty sure it had something to do with Sketchup not storing the component in the “components” preference location.
Another way to save components is to drag and drop in the Components panel. You might try that.
When you context click and choose Save as… you select the save to location. I save components to specific collections(folders) based on what they are so I can find them more easily.
What I actually have done is pin the folder path to my File Explorer taskbar icon and then it’s available via a context click on that icon. (Home > Pin to Quick Access. But you can also drag and drop folders onto the taskbar File Explorer icon.)
Well, I’m back to trying to use components, having no luck at all. SU2017 Make wants to use the 3D Warehouse no matter what I do to discourage it. Basically, I want to assign a local extensions folder (and NOT the deeply-buried default) once, and have it used for all components in all models I work on on this computer. Is this even possible?
Gosh, this is getting old. I thought I was getting somewhere, but…
I set Window->Preferences->Files->Components to point to a folder on my PC. Then when I create a component, it sure-enough puts it in that folder, and I can then retrieve it later.
However, if I open another instance of Sketchup, with the same preferences specification, it doesn’t find the component I just put there. Also, I just noticed that if I continue to create components, they don’t show up in the folder – only the first one is there.
Can you not retrieve a component into a different model? Makes no sense.
Where is that folder you created? If you created that folder in the normal user location
The folder should show up automatically in the Components drop down list. If you put that folder elsewhere, even though you’ve set that as the save to location, you need to point SketchUp to it or it has no idea that it exists and won’t show it in the drop down list. Open the Details menu and choose Open or Create a Local Collection.
If you want that to always collection to always show in the list, open the Details menu again and choose Add to Favorites.
If you are sorting your components into categories, one save to location in Preferences won’t be enough. I’ve currently got 22 different categories of components listed in my drop down.
Thanks again. Working now. The key was “even though you’ve set that as the save to location, you need to point SketchUp to it or it has no idea that it exists and won’t show it in the drop down list…” I thought that setting the Preferences did point Sketchup to it.
That tells SketchUp where to save components when you right click on them and choose Save as… It doesn’t tell SketchUp where you what folders you want to show in the Components window.
Generally when I want to save a component I’ve created into a local collection, I open the secondary pane, set it to the desired collection and drag the component from In Model in the top pane to the collection in the bottom pane. I find it easier and faster than navigating to the folder in the File Explorer.
Thanks again. I’m not sure how I got them all into the local collection, but I’ll adopt your method. Wish we were Vulcans - a partial mind meld now and then would be really handy.
