Hi Guys,
I’m attempting to create a hinge for a piece at work, but cannot seem to get a section to cover properly:
Please see attachments, I’ve highlighted the area in blue, which I’d like covering if possible?
Any idea what I am doing wrong? I have tried to go around the perimeter of the area with the draw tool, but it doesn’t seem to join up
hinge.skp (191.8 KB)
EDIT: Actually, I may need to put vertical lines in where the curves are? I’ll give it a try when I am back at work tomorrow!
Your circular “cut-out” actually extends into the material beyond the arc of the notch…
hinge 1.skp (224.3 KB)
I just pulled the notch up, pulled the circle across and intersected the two shapes - there are three faces you need to add, not just one. (Since the faces were created from negative space I had to invert them)
Hi gadget2020,
Thanks a lot for doing that for me!
I’ll be honest though, I don’t full understand how you did it, but really appreciate the help, as that is what I was wanting!
Thanks
Chris
This should explain: very simple steps hinge 1.skp (243.0 KB)
Hi Gadget2020,
Apologise for the late reply!
But thanks a lot for explaining that! It will really help in the future.
Thanks a lot
Chris
