"Fill" not imported into LayOut
Hi,
I have added a fill pattern in Sketchup to represent insulation between walls. For some reason, this has not imported into Layout (See two images attached - top image is from Layout). Does anyone know why this has happened and what I have to do to rectify it.
Many thanks,
Adam
Does setting your Viewport to “Hybrid” fix it?
How do I do that?
Vector rendering won’t show raster textures which is what your fill pattern is. Select the viewport and in the SketchUp model panel change the rendering type to Hybrid.
That did the trick - thanks!
