I’ve done something to this file that I didn’t intend to do and don’t know what it is; so I can’t fix it.
In the attached file, now lines or other drawing action remains in the drawing. I’m pretty sure that my ignorance both caused it and prevents me knowing how to fix it.
I cannot draw a line that will remain in the drawing. I’ve tried lines in space and lines connected to existing objects with the same result. I also noted that detail is lost in the table top lines.
My guess is that there is some variable in SU that I managed to activate or deactivate accidentally because I didn’t do it intentionally.
Also took a look. No problem drawing new lines either. Did notice you have some reversed faces here and there that should be taken care of. Few other things I found a little “odd” in how you’ve structured the model …But everyone has their own way I suppose
I edited the Style to turn Profiles on. The lines that I had drawn appeared but they were exceptionally thick, unlike lines I drew before the problem appeared. The appearance is still not as sharp and crisp as it was before.
