Field of view in saved view keep changing, how to fix
same view, same file, we change vRay safe frame to render different scenes and after a while the field of view won’t be the same as first saved.
How to fix it? as it s pretty big drawback not being able to go back to the same scene and rerender if the field of view is different
As example i uploaded the screenshoots of the same view, notices the field of view has changed.
Try uploading your screenshots again. Wait untill they are uploaded before entering the post…
Hi there, uploaded the screenshots, not sure if is the field view or also the zoom that changes… it happens after switching vray render output settings, ( eg portrait view, landscape view etc)
Is that a 2-point perspective?
Have you created a scene with the camera position and field of view set?
I can confirm I’m having the same issue, only in Windows. A similar bug that happened years ago and seems to be back. This kills my workflow.
yes is terrible for workflow… I create a scene with camera aligned to section, set field view and didnt notice if it happens for both 1 or 2 point perspective, in any case the perspective view is part of the setting that are saved.
