Vray 5 + Sketchup - scene changes slightly between repeated renders
Hello,
I recently upgraded to Vray 5 and have experienced that the scene sometimes changes slightly when I do repeated renders. To be clear: Even though I am using the very same scene in Sketchup and has safe frame activated in Vray, there are sometimes small changes in the rendering result, like as if the camera has moved a few decimeters sideways.
Are there anyone else who have experienced this issue with Vray 5?
The issue is very annoying since it makes it difficult to do post-production effectively (ie. masks in PS has to be updated due to the small change in angle).
I never experienced this issue with previous versions of Vray.
(At the same time I also updated to Sketchup 2022 from Sketchup 2020. Could the Sketchup-version be related to this issue?)
Please update your profile, this is confusing. What version of SketchUp are you actually using? Are you eligible to use 2022?
Hi, yes I updated the profile now.
The problem occurs when I’m using Vray 5 and Sketchup Pro 2022. Sorry for the confusion.
