I am making some technical figures and looking for a fade-out look on the edges of a viewport in Layout. Using fog is nice in SU, but it doesn’t work with LO vector, and you can’t apply it in multiple planes.
I have played around with importing a white transparency gradient as a pattern - but applying it around as a shape is a little manually intensive and clunky. Any better alternatives I’m missing?
I’m trying to get a shop drawing set out so I don’t have a lot of time to play - but if you don’t have a lot of them - make a screen shot, open in Photoshop (or similar) - add a layer, use gradient fill, adjust your center / etc. - delete the original layer, use a mask to create the fade from the gradient fill, then export a transparent PNG and import into LayOut.
The circular/radial gradient might be the best I can get easily - but ideally, I’d want to make a custom transparent shape and “frost” the edges. Kind of like the basic “Soft Edges” picture-effect-feature Microsoft Office products have.
I use a set of four gradient rectangles (transparent pngs) around master plans and other exhibits all the time. They are quickly adjusted and stretched in a group in LayOut. Not ideal, but a fairly simple once you get the hang of it. Attached my version that you can play around with. Good luck! White Vignette.layout (62.3 KB)
