trying to model a rolled edge, typical of what would be hard tooled in the sheet metal industry
Need to model a triangle 12" X 8 1/2" X 81/2", 1" radius corners, 1/2"x 90 degree extruded edge in 1/8" sheet metal, as per attached image. Does anybody how to perform this ?
You didn’t give the radius of that bend so I didn’t draw it. Make the profile with the needed radius before running Follow Me. Otherwise the process is the same.
Same way as @DaveR showed, just used a different profile in followme. (The warning that pops up is a common occurrance with followme, and if the results look ok it can be ignored). Given the size of the object involved, you might need to scale up by a factor of 10 before doing this to avoid small edges issues.
