Extensions when a new file is open
Hello friends, whenever I open a new file in SketchUp 2025 my Extensions are scattered around. Is there a way to have them neatly organised in the top bar automatically?
This is usually caused by windows permissions issues.
One option to fix it is to find your installer .exe or download a new version, Select it, right click and choose Run as Admin, then follow the prompts and choose Repair.
Then reboot your computer.
Hello
make sure you save your model at least once (even if empty, and save it anywhere) right after organising your toolbars and before closing SketchUp, also make sure you don’t have multiple instances of SketchUp running before doing so
Thank you, I’ll give it a go.
also, whenever sketchup crashes, it’ll launch with the latest “stable” UI. so if you change stuff, then crash, it’ll rollback to before the change.
if several instances of sketchup are open, it’ll save the last one you close as the “safe UI”.
