Extensions or plugins
I got curveiloft from SketchUcation. It is in my extensions manager and is enabled. How do I access them for use?
You should be able to open its Tool Palette under View>Tool Palettes. Make sure you’ve also installed the required LibFredo6 files from Sketchucation, too.
I don’t have Fredo6 in tool palettes but I do have a Fredo6 settings in Windows. I don’t know about the required files. I have Curviloft_v1.8a.rbz, is that it?
It’s LibFredo6 and you shouldn’t have a tool palette for it. LibFredo6 is a bunch of support files that are common to many of Fredo6’s extensions. There will be a LibFredo6 Settings menu entry in the Window menu.
The current version of Curviloft is v2.4b from Feb 10th of 2020. If you don’t have that one you should go to Sketchucation and get it.
What version of SketchUp are you really using? Your profile says you are using “SketchUp Free(Web) 2021” which cannot be correct. Please update it to the correct version because that information helps us help you.
I am using the 30 day trial of Sketchup Pro. I have Curviloft v1.8. I guess I must update
So you are still using SketchUp Pro 2021 and not the free web version. Please fix your profile.
Yes. You should. And also make sure you’ve installed the latest LibFredo6.
I tried to fix my profile but it won’t change.
I’ll try to install LibFredo6.
How did you try to fix it? Click on your avatar image in the upper right corner of the forum screen. Then click on the person icon followed by Preferences and then Profile.
And don’t forget to scroll to the bottom once you have made the changes and click the Save Changes button.
