An Extension install issue: I want to get some additional extensions in the Extension Warehouse but when I press Install, the screen is blocked by a HUGE lawyer-speak page of nonsense! How do I access the Extension Warehouse? It used to be a simple and useful feature!
Are you using the Extension Warehouse UI in SketchUp or are you using your internet browser? The former would be more straightforward, with the latter, make sure you are signed into your Trimble account.
Can you share a screenshot of what you are seeing?
I see this in both the built-in UI and in my web drowser.
I’m using through SU not Browser
Have you tried scrolling down to the bottom of the page to click the Agree button (or whatever it is)?
When you installed SketchUp 2024 did you do so correctly? That requires that you right click on the installer file you downloaded and select Run as administrator. If you don’t do that Windows may not set permissions to allow SketchUp to write files like the cookie that’s created when you agree to the Terms of Service.
It looks to me like perhaps you have Windows text scaling set way too high.
Check it out via:
Start > Settings (Windows+I) > Accessibility > Text Size
Setting it higher than 125% will be problematic for SketchUp Chromium-based dialogs, especially with SU24. (Chromium versions used in prior SketchUp versions did not add in system text scaling on top of display scaling.)
Also make sure that your general display scaling is at recommended value:
Start > Settings (Windows+I) > System > DIsplay > Scale
