Extension loading issue
Hello
  1. Taking online SketchUp for Landscape & Site Design practice course learn.sketchup.com
In part 1 we are learning CAD clean up and making faces.
  1. Having an issue with extensions not showing in extensions drop down list.
  2. Online course suggests the EdgeTools2 extension to close line gaps:
  1. I installed as shown:
19%20PM
  1. But when checking get this message:
02%20PM
  1. I can’t find the Extensions tab in the Preferences menu. Where is this located?
  2. I have also tried restarting SU.
File size too big to upload here.
Thanks!
I’m on windows, so I hope this helps.
EXloading
Thanks, I’m aware of the Extensions Manager, but pop up says ‘Preferences’
which is possibly where the confusion lies.
I’ve tried to load again and again and still get the same message. Extensions says it’s loaded but not showing up in manager:
  1. INSTALL
  1. CONFIRM
26%20PM
  1. SAYS SUCCESS
39%20PM
  1. DROP DOWN DOES NOT SHOW SUCCESSFUL DOWNLOAD
09%20PM
  1. WHEN I CHECK EXTENSION WAREHOUSE, EXTENSIONS STILL SAYS “INSTALL” WHEN IT SHOULD SAY “UNINSTALL” IF IT WAS INDEED INSTALLED SUCCESSFULLY
Hello
I just located the extension. Rather than being list on the extension drop down, it was placed at the bottom of the tools drop down which is a bit confusing.
Thanks for your help
It’s a good idea when installing extensions from the Extension Warehouse to scroll down a bit to read instructions and such. There’s information about where you’ll be able to access the tools and also if there are any required support files needed.
Thanks
Thanks
Daniel
Daniel O’Kane
CAL LIC #1038951
This is a bug. The Extensions panel of the Preferences dialog was moved to it’s own Extensions Manager dialog with the 2017 release.
So this informational messagebox you see (in versions greater than 2016,) should have been revised so that the 2nd sentence reads, “To load the extension go to the Extensions Manager window and check the box next to the extension.”
@thomthom, can you check to see if this issue has been logged internally for the Mac builds ?
Thanks!
Thanks
Daniel
Daniel O’Kane
CAL LIC #1038951
Logged as SU-42963
Thanks
Thanks
Daniel
Daniel O’Kane
CAL LIC #1038951
