Help please!
In layout my page is showing correctly, but when I export to pdf/or 2d image, the edges are misplaced. How do I fix this? When using 2022 version this never happened
What it delivers after exporting:
Thank you
Help please!
Thank you
We’ve seen that happen when the model is located at a huge distance from the origin.
Share the LO file so we can see your exact setup.
What operating system are you using? You put ‘2023’ as the answer to that question in your forum profile but that’s not a correct response.
The easiest thing to do is to stick to Raster rendering. Use High resolution. Turn off Jpeg compression in PDF output.
Hi Anssi,
Thank you so much!
It worked ![]()
