Hello. I got a problem with presenting my image in good quality and high resolution. I tried to render it by Indigo but in trial version it keep watermark. I habe not succeeded to transfer file into Adobe Illustrator. Can someone help me? Thank you!
for raster formats use “File > Export > 2D Graphic > Export Type: PNG” in connection with the “Options…” button for configuring the desired resolution.
if you wanna export vector data you can export to the PDF/EPS format (losing textures, shadows, tranparency) as described above (SU Pro feature only).
To create a vector drawing from SketchUp Make that can be opened in Illustrator or other drawing applications you can print your view using a PDF printer with the “Use high-accuracy HLR” print option enabled.
Using a commercial rendering package usually means that you have to pay for it. There are free rendering applications too, like Kerkythea.
Anssi
