Export to vector file
Hello,
I am trying to find a way to export wireview to a .eps, .ai or .cdr file in order to import into coreldraw.
I have exported as dxf or dwg however the files are much to large and they have thousand of pieces.
Is there and addon or a resolution to this issue?
In addition to dwg and dxf, SketchUp can also export to eps and pdf.
All the 2D vector export formats however produce an essentially identical result, with arcs and circles converted into straight line segments.
I get best results exporting as dwg 3d and under the export options uncheck the “faces” box. Just edges. This gives arcs and circles. However they may be multiple duplicates created that can be removed by routine depending on your software.
