Export eps or 2D dxf or 2Ddwg
Hi all,
I try several way to export an 2D dxf or 2D dwg or a eps with the api of Sketchup pro 2014 MAC 14.1.12.83. I can export 3D dwg or dxf, 2D png but I don’t find a way to do it.
Sketchup.active_model.export ‘/Users/DenisBolomier/Desktop/toto.eps’, false
false
Sketchup.active_model.export ‘/Users/DenisBolomier/Desktop/toto.eps’, true
false
Sketchup.active_model.export ‘/Users/DenisBolomier/Desktop/toto.DWG’, false
true
Sketchup.active_model.export ‘/Users/DenisBolomier/Desktop/toto.dxf’, false
true
Sketchup.active_model.active_view.write_image “/Users/DenisBolomier/Desktop/test.jpg”
true
Sketchup.active_model.active_view.write_image “/Users/DenisBolomier/Desktop/test.eps”
false
Yea, I think that’s missing from the API I’m afraid. I believe we have an issue logged for that.
pokes @ChrisFullmer I’m not making it up when I say we have an issue already, right?
Thanks tomtom!
One more question pdf, doesn’t work too ? in fact no vector format is working ? (sorry for english mistake)
PDF export is missing from Windows, while it do work under OSX.
3d vector should work, DXF, DWG etc. But no 2d.
Thanks TomTom, I will use Sketchup.send_action 21237 and put a sone on my “enter” key.
OR ( and this is the master plan :smile: )
  1. replace the sheet of the watercolorbot.com by my keyboard
  2. replace the pencil by a reverse pen
  3. in ruby Sketchup.send_action 21237
  4. in ruby send to the watercolorbot webservice the action to push and release the enter key of my keyboard, …
let’s go develops the “hand-made API of Sketchup”
In fact I discover that send_action is asynchronous !
arrrrrg, bot is the last chance to escape 1000 drawing conversion.
(3D vector export is pollute by showing all the edge )
You could try to send key-presses that automates the UI. Fragile, though… not pretty at all.
We use auto-it or sikuli for Sketchup automation sometimes for testing purposes. Its fragile from version to version. But once you get good at it, its pretty easy to keep updated.
Awesome !! We install and use Sikuli and it’s work’s well !!. Tanks you Chris !
Great, glad that helps!
Did 2D DWG export ever make it into the API?
Anything?
