Hi there, I having an problem exporting to AutoCAD. I tried different Sketchup versions on different computers 8, 14, 2019. The DWG file is produced, but with an error message
S8 does a Bug Splat - produces no DWG file
S14 says an error occured while attempting to translate this model - produces no DWG file
S2019 Trial The DWG file is produced, but with the error message in the title.
Here is the model. It is my new house and I need to send it to an structural engineer as DWG. Can anybody fix it or tell me what the problem is?
S19 - AutoCAD export audit error: Check ‘Audit report.txt’ for errors.
S14 - An error has occured while attempting to translate this model
S8 - Bugpsplat Screen with no real details.
The question is can anyone open the model (Ver 8) and sucessfully export to 3D AutoCAD DWG or DXF?
I too got an Audit report file, with nothing intelligible inside. But SketchUp still did create a DWG file. It looked OK in Autodesk TrueView but only you, @christopher.lambe can say if something is amiss. I don’t know what causes the error message, but you might try shortening and simplifying some of the layer and component names. I wouldn’t use, for instance, parentheses, preferably only letters and numbers. EFH Lambe 20190325_Bruno.dwg (472.7 KB)
Edit:
I tried different approaches: Deleting all layers didn’t make a difference but exploding everything down to raw geometry did - that produced a file with no error message: EFH Lambe 20190325_Bruno2.dwg (608.8 KB)
