I have some stl files of gears that were sent to me and i am wondering if sketchup can somehow convert them into a file that can bu used with lightburn so i can cut them out of my 6mm plywood i have. Maybe export as a svg or something.
They need to stay the exact size they are. I know they were created with fusion 360 and so the stl (even though its unitless) was saved with correct units so it opens in a slicer the correct size.
I got the same results. The segments of the model are very tiny so I imported them using Meters as the model unit. Still the result was the same. They opened in Rhino OK.
same, they printed fine for me but SU does nto like them. Somehow i need to get them to my laser cutter TODAY since this is for my active drag system for a rocket for senior project.
Here are your parts as saved from Rhino as SKP. There might be holes due to the very tiny segments. Blade+Rack.skp (240.1 KB) Smaller Driving Gear.skp (1.2 MB)
