Errors removal in sketchup pro
These are the errors crop up while starting SketchUp pro. Can anyone help in fixing these issues.
Error Loading File C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb
Error: #<RGLoaderError: RubyEncoder Loader - This protected script is not licensed to run on this machine. Please contact the script author about this problem. Error code [03]>
eval:6:in `RGLoader_load’
eval:6:in `<module:Skalp>’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb:481:in `skalp_require_isolate’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb:481:in `<module:Skalp>’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb:1:in `<encoded>’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb:6:in `RGLoader_load’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp/Skalp_loader.rb:6:in `<top (required)>’
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require’
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp.rb:99:in `register_extension’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp.rb:99:in `load_extension’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp.rb:80:in `check_IE_version’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp.rb:128:in `<module:Skalp>’
C:/Users/Dr. Sunil/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Skalp_Skalp.rb:15:in `<top (required)>’
The error messages are in English. You may be able to understand some parts of it, for example
Most extensions allow to apply a license after starting SketchUp. If that is not the case with Skalp, maybe it has a separate installer executable?
  • Try uninstalling and reinstalling Skalp.
  • Since Skalp is a commercial extensio and you are a customer, you certainly get professional support be the Skalp authors. Try to contact them.
Skalp claims that version 2.0 is free (thank you !) and will work for SU Make and Pro.
However every attempt at loading the extension fails with the exact error above.
The script uses RubyLoader (minGW) to load a Base64-encoded text. Either every available ruby loader is expired, or the translator script is expired. I did try to replace the current with a file from version 4 of skalp. Also failed. The extension should be updated if possible.
See this post …
Skalp isn’t dead - #76 by Thom17043
So, people wish to monetize on their work, fair - that’s their choice. But then the extension should be removed from the extension store in my view. There are 3 different scalp versions available listed as “Free”. None work.
Meanwhile this “security” argument …hmm… just be honest. Loads of extensions that list “minimum 2019 version” work perfectly fine on 2017 Make. I don’t know if the “security” is only in the translation module, basically reading ini files. If it is, even more sad.
Again, no argument against switching to paid-only. But at least remove things that no longer works.
