Error message on startup
As of yesterday morning, every time I start sketchup I get about 8 of these error boxes for different plugin I have installed. I also get this log files come up when I close the first one. All the plugins work as expected, so not sure why these are coming up, and what triggered it?
Hello, contact https://support.mindsightstudios.com/hc/en-us/
As it is related to your artisan 2 licence. The others might also be linked to other might sight studios plugins.
Perhaps you can try adding a licence to them again ? Check in their respective menus if you can find a licence section
Yes I did think it was the mind sight stuff, but also bunch of fredo6 plugins come after I click ok. Might just have to go through all the licenses and re add, will report back if fixed.
The Fredo6 plugins are distributed on SketchUcation.
Go there and find out if there was an outage in their license server.
Yes interesting, currently I think there must be a problem with Sketchucation, I can’t seem to even log into the website, can you check if you’re having same issue?
works fine here, do you have a firewall activated ?
working fine again now, must have just been a momentary thing, still have these errors so will uninstall reinstall and see if sorts it
I would update your sketchucation plugin as that is what controls the licenses and if out of date will have issues.
